Why did you removed PETSC_ARCH_NAME variable in makefiles?
Lisandro Dalcin dalcinl at gmail.com
Thu Nov 26 14:40:40 CST 2009
On Thu, Nov 26, 2009 at 3:21 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> On 26/11/2009, Lisandro Dalcin wrote:
>> On Thu, Nov 26, 2009 at 2:20 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> We fixed slepc-dev so that PETSC_ARCH_NAME is not required anymore.
>> Jose, could you elaborate a bit what would the rules be now for SLEPc?
>> Building SLEPc with a prefix build of PETSc will require SLEPc's
>> configure to also pass explicitly a--prefix and do "make install"
>> after the build?
>> I still have to figure out how to make both models (I mean, prefix vs.
>> multi-arch) builds work in the case of petsc4py/slepc4py and their
>> dependencies on themselves and with core PETSc/SLEPc...
> SLEPc can be setup with or without prefix, irrespective of whether PETSc is
> prefixed or not.
> Since we need a PETSC_ARCH, one could set an arbitrary value of PETSC_ARCH,
> then configure (with or without prefix)+make+(make install).
> If the user does not set PETSC_ARCH, then SLEPc's configure will tell the
> user to set PETSC_ARCH=unknown before invoking make.
OK, now Jose just introduced another standard: an non-prefix SLEPc
build with a prefix PETSc build is equivalent to a non-prefix PETSc
with PETSC_ARCH=unknown, and... This is a nightmare... I'm a bit lost
about what to support and what not in petsc4py/slepc4py...
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
