Why did you removed PETSC_ARCH_NAME variable in makefiles?
Jose E. Roman jroman at dsic.upv.es
Thu Nov 26 11:20:28 CST 2009
On 25/11/2009, Barry Smith wrote:
> Why does SLEPc's configure.py need to know PETSC_ARCH? PETSC_ARCH is
> a just a string that the user made up; in the --prefix case it means
> nothing at all and has no information associated with it.
> If you are installing a SLEPC based on a --prefix install of PETSc,
> you can just make up any PETSC_ARCH and use it doing your ./
> configure and make. If you are also doing a --prefix for SLEPC
> (which is likely when PETSc was done with --prefix) then once you
> have done make install the need for that PETSC_ARCH is gone. If you
> are not doing a --prefix for SLEPc then that PETSC_ARCH is what the
> user will need to use when they use the SLEPc. Does this not work
> for some reason?
>  Barry
We fixed slepc-dev so that PETSC_ARCH_NAME is not required anymore.
Jose
