-malign-double
Jed Brown jed at 59A2.org
Sat Nov 14 10:28:31 CST 2009
Barry Smith wrote:
>    Good point, I have removed it.
>    I put it in because I wanted an easy way to test that PETSc double
> arrays are always 8 byte aligned (and the unaligned struct values were
> giving me lots of false alarms).
A related issue is PetscMallocN which (in optimized mode) gives
unaligned arrays even if malloc always returns aligned memory.  Consider
  PetscMalloc2(3,PetscInt,&ai,3,PetscScalar,&a);
I think it is preferable for PetscMallocN to align all the pointers.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091114/d23b1e2c/attachment.sig>
