-malign-double
Fri Nov 13 20:09:04 CST 2009
    Good point, I have removed it.
    I put it in because I wanted an easy way to test that PETSc double
arrays are always 8 byte aligned (and the unaligned struct values were
giving me lots of false alarms).
    I guess we can test for double align on x86_64 systems.
    Barry
The IBM BlueGene doesn't like 4 byte aligned doubles and sends a bus
error after a certain number are generated, Thus I was motivated to
make PETSc a bit clearer on that.
On Nov 12, 2009, at 9:29 AM, Lisandro Dalcin wrote:
> On Wed, Nov 11, 2009 at 11:02 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>  Satish,
>>    gcc supports the option  -malign-double on some systems. Please
>> add it to
>> the flags that configure checks for c and c++ and have it added if it
>> exists.
> Definitely -1. Why are you asking for this? On x86_64 this is the
> default. In i386, this flag is likely going to break ABI's.
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
