VecGhost trouble
Wed May 20 12:34:23 CDT 2009
    Jed,
      These are likely there because MatGetVecs() was introduced
pretty recently and those are places that "never got fixed" when
MatGetVecs() was introduced.
      Please feel free to fix and push.
     Thanks
    Barry
On May 20, 2009, at 11:49 AM, Jed Brown wrote:
> I have some heavy use of VecGhost with MatShell (so the ghosts are
> required to define MatMult).  While exercising this framework, I have
> noticed some operations that do not work correctly, in particular
> * MatComputeExplicitOperator uses VecCreateMPI rather than MatGetVecs
> * same pattern in MatNullSpaceTest (if there are no vectors to
> duplicate in the null space, i.e. just the constant)
> I think these cases can just use MatGetVecs which I can use to produce
> the correct vectors.  Any problems with this?  (Any reason the current
> code calls VecCreateMPI directly?)
> Jed
