VecGhost trouble
Jed Brown jed at 59A2.org
Wed May 20 11:49:29 CDT 2009
I have some heavy use of VecGhost with MatShell (so the ghosts are
required to define MatMult).  While exercising this framework, I have
noticed some operations that do not work correctly, in particular
* MatComputeExplicitOperator uses VecCreateMPI rather than MatGetVecs
* same pattern in MatNullSpaceTest (if there are no vectors to
duplicate in the null space, i.e. just the constant)
I think these cases can just use MatGetVecs which I can use to produce
the correct vectors.  Any problems with this?  (Any reason the current
code calls VecCreateMPI directly?)
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090520/64249ead/attachment.sig>
