TS_RK enhancements
Thu May 14 14:36:41 CDT 2009
    Kai,
     Thanks for the patch. I have applied it and pushed to petsc-dev
> The reason why I care about max_steps is that I'm using petsc to
> drive an AMR code (not just TS_RK, I alternatively use TS_CN). Now
> this is pretty much a much bigger beast and I guess it's open for
> discussion as to whether petsc wants to add the complexity to
> support this better. In an AMR code, timestepping as such shouldn't
> be that different in principle, but it really does add complexity:
> One of the fundamental operations in AMR is to refine/derefine the
> grid, which means that the state vector changes, and with it all the
> operators / nonlinear function etc. The hack I'm currently using is
> to use TS to integrate the system for a number of timesteps, then I
> check whether regridding is necessary, and if so, I build a new
> state vector etc, throw away the old TS and create a new one. As I'm
> in general in favor of avoiding bloat unless it's well justified, I
> can't really see a good reason to put all this logic into TS, unless
> there are other users who need it.
> It woulde be nice, though, to extend the TSSetUpdate() hook to
> indicate to TS that it should break out of timestepping now. Then I
> could put the regridding check into the TSUpdate(), and if
> regridding is necessary, have it break out of the timestepping. One
> potential way of doing this without adding yet another flag would be
> to break out if TSUpdate() sets dt to zero, assuming there's no
> legitimate reason why an application would want to do that
> currently. (or one could use a negative dt as a flag, but who knows
> whether there might be a valid reason for a negative dt...)
> If this sounds reasonable, I'd give it a shot.
> As I've just now started to look at the code, it appears to me I may
> be opening up the usual can of worms. Unless I'm missing it in some
> ungrepable header, I don't see ops->update being called currently in
> the first place, so I'd fix that, too. In addition, I see "reform()"
> and "reallocate()" methods in TS, which sound like someone might
> have worked on something like the more complex AMR scenario I
> described above, but they're never actually used at all AFAICS.
> More of that: prestep() and poststep() are actually implemented, but
> don't seem to match the description as they're called before / after
> each timestep, not once in the beginning / the end. I think the bug
> here is the description, the names match watch they do. Except that
> really these functions should have the *dt argument to set a
> timestep (prestep, at least). update(), if it were implemented,
> would be called before each r.h.s. evaluation which for RK would be
> each substep, and changing dt at that time is likely to lead to
> garbage. Does anyone feel responsible for the TS interface, or
> should I have a go at proposing something I consider sensible?
    There is no one who is coordinating the TS interface at the
moment. So you are welcome to propose changes/fixes/improvements and
are in as good as a position as any of us.
    I see there are four methods: prestep, poststep, update,
postupdate; as you noticed the naming and usage of them is a bit
inconsistent. Even the TSStep() function has a confusing name since it
actually takes (potentially) many steps.  I suggest starting the
following possible changes.
    change TSStep to TSSolve(),
    move the prestep() and poststep() methods to be the ones used AT
the beginning and end of each timestep (not called in TSSolve())
    eliminate update() and postupdate() confusing names anyways
    determine if there is a need for a pre and post called in
TSSolve() could call them presolve and postsolve if you put them in.
    do we really want prestep and poststep deciding to kick out of the
iteration or do we want yet another method (corresponding to the
converged() method in KSP and SNES) that is used to exit early from
the solver?
    I think using a flag to exit early from the solver is better than
setting dt to zero.
    having the steps and ptime output arguments from TSSolve() I think
is wrong. They should be kept in the TS object and then calls like
TSGetSolveTime() and TSGetNumberSteps()
    to access them.
   So some of the reorganization would be to make the use of TS match
more closely SNES and KSP.
    Barry
> --Kai
> Kai Germaschewski
> Assistant Professor, Dept of Physics / Space Science Center
> University of New Hampshire, Durham, NH 03824
> office: Morse Hall 245F
> phone:  +1-603-862-2912
> fax: +1-603-862-2771
> <pp-ts_rk>
