SNESSetUp() and matrix-free options
Wed May 6 15:53:49 CDT 2009
On May 6, 2009, at 3:37 PM, Lisandro Dalcin wrote:
> On Wed, May 6, 2009 at 5:25 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>   Lisandro,
>>     The checking of the options can be moved to
>> SNESSetFromOptions() that
>> then set some flag in the snes object;
>> but the actual action of MatCreateSNESMF() etc must continue to
>> take place
>> in the setup.
> Could you elaborate a bit more on this requeriment on the call to
> MatCreateSNESMF()?
     Hmmm, maybe it would ok to move all of it into
SNESSetFromOptions().
My thought was it had to be in the SNESSetUp() so that it would
override anything
set by the user code. But so long as SNESSetFromOptions() is called
after SNESSetJacobian()
then it will override.
    It is ok with me if you try moving it all.
    Barry
> The problem I see is that SNESSetFromOptions() calls
> KSPSetFromOptions(), but before that, we should be calling
> KSPSetOperators() because KSPSetFromOptions() sets some defaults based
> on the actual subtypes of the Mat operators... Likely we have a
> chicken-and-egg problem here...
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
