logic of config options
Wed May 6 09:24:59 CDT 2009
On Wed, May 6, 2009 at 9:17 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 5 May 2009, Giuseppe Ghibò wrote:
> > Hi.
> > I'm trying to package petsc 2.3.3,
> Why package this older version? Current version is 3.0.0.
> > but I didn't understand the logic of some options, in particular for
> > umfpack.  E.g. If I specify at the config stage:
> > --with-umfpack-lib=[${_libdir}/libumfpack.a,${_libdir}/libamd.a]
> > and the ${_libdir} path contains both shared and static libraries then
> > the linking command are expanded to:
> > -lumfpack -Wl,-rpath,<path of petsc> -lamd
> > Ditto if I specify:
> > --with-umfpack-lib=[libumfpack.a]
> > they are expanded to the two libs "-lumpack -lamd" (i.e. it guesses the
> > other lib "libamd" even if I don't specify).
> petsc-3.0.0 won't add the extra -lamd
> > So what is the logic behind the --with-xxx-lib option?  Should I
> > specify just the list of comma separated libraries enclosed in
> > '[...]' pair?
> Yes - this is the python list syntax that configure accepts. However
> It should also accept "-Lfoo -lbar" syntax - but it appears to do this
> for only a few packages. [Nees fixing?]
> > And how to force the usage of static libraries when both shared and
> > static exists?
> Currently this is not possible. Perhpas it will be if "-Lfoo -lbar" is
> supported.
You can force in a library using the full path. I think the right way to do
this is
to make the compiler choose the static library. Many compilers have options
for
this.
> > Because in other cases I see it could be specified also the linking
> > command. E.g., if I have a system-wide lapack library, I could use:
> > --with-lapack-lib=[-llapack]
> > but this sound working in some option and not in some other. So what
> > is the "right way"?
> yeah - its an inconsitancy on our part...
What is an example of an inconsistency?
  Matt
> Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090506/cb02dcf2/attachment.html>
