hypre
Mon Jun 8 16:15:27 CDT 2009
    1) you probably don't need shared libraries
    2) Did you run config/configure.py with the option --with-shared,
if not they are turned off by default
    3) In general one can build the shared libraries and use hypre
     Barry
On Jun 8, 2009, at 4:12 PM, Giuseppe Ghibò wrote:
> Hi, I'm trying to build petsc (the 2.3.3p15 version because needing to
> use libmesh), with hypre lib enabled, but when doing this,
> the shared libraries are not built, and I get:
> Completed building libraries
> Shared libraries disabled
> while this doesn't happens when hypre support is not build. Are hypre
> and shared libs mutually exclusive?
> Thanks
> Bye
> Giuseppe.
