GMRES and PC_RIGHT
Mon Jun 8 15:52:31 CDT 2009
On Jun 8, 2009, at 3:46 PM, Lisandro Dalcin wrote:
> Well, all you say that GMRES is not coded for right PC's, however,
> after reviewing (in a hurry) the code for GMRES, it seems to handle
> right preconditioner. Moreover, I've just tested solving (with SNES) a
> steady lid-driven cavity flow in 2d with linear quads using SUPG/PSPG,
> default tolerances, default restart, no diag-scaling, starting with
> zero nonlinear guess ...
    Does nonzero initial guess work properly?
> in short, using -ksp_right_pc and just
> changing -ksp_type to gmres/fgmres, and ALL the SNES iterates (up to 3
> nonlinear its) and GMRES|FGMRES iterates (64, 169, 177 linear its) are
> almost the same (except the last four digits using default KSP
> monitor).
> Sorry for the insistence, but ...  Am I missing something? Do any of
> you remember exactly what part of GMRES had problems with right
> preconditioning?
    Sadly, no I do not remember the exact issue with right
preconditioner; I was thinking it was more or less completely broken.
    Barry
> On Mon, Jun 8, 2009 at 4:27 PM, Jed Brown<jed at 59a2.org> wrote:
>> Barry Smith wrote:
>>>    The FGMRES code was written for right preconditioning (but the
>>> FGMRES
>>> algorithm itself does not support left preconditioning.)
>> LGMRES has both so that's another option.
>> Jed
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
