GMRES and PC_RIGHT
Lisandro Dalcin dalcinl at gmail.com
Mon Jun 8 15:46:16 CDT 2009
Well, all you say that GMRES is not coded for right PC's, however,
after reviewing (in a hurry) the code for GMRES, it seems to handle
right preconditioner. Moreover, I've just tested solving (with SNES) a
steady lid-driven cavity flow in 2d with linear quads using SUPG/PSPG,
default tolerances, default restart, no diag-scaling, starting with
zero nonlinear guess ... in short, using -ksp_right_pc and just
changing -ksp_type to gmres/fgmres, and ALL the SNES iterates (up to 3
nonlinear its) and GMRES|FGMRES iterates (64, 169, 177 linear its) are
almost the same (except the last four digits using default KSP
monitor).
Sorry for the insistence, but ...  Am I missing something? Do any of
you remember exactly what part of GMRES had problems with right
preconditioning?
On Mon, Jun 8, 2009 at 4:27 PM, Jed Brown<jed at 59a2.org> wrote:
> Barry Smith wrote:
>>    The FGMRES code was written for right preconditioning (but the FGMRES
>> algorithm itself does not support left preconditioning.)
> LGMRES has both so that's another option.
> Jed
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
