When was the last time MatScalar was supported?
Jed Brown jed at 59A2.org
Mon Jun 8 06:15:42 CDT 2009
Thanks Barry,
Barry Smith wrote:
>     It never worked in general. It was done originally and worked for
> BAIJ matrices with block size 4 to run PETSc-fun3d fast that is all it
> worked for.
Sure enough, I was wondering why that's the only place I read about it
being used.
>     I think it is much harder to get working completely then you think.
> It is more than just changing a few PetscScalar in the code to
> MatScalar, there are I think lots of situations where copies of stuff
> (with proper casting) have to be made to be passed in.
I noticed that a lot of copying would be required, but not in the public
interface.  I guess it looked like internal wrappers to MatSetValues and
a couple variants would handle most of these cases, but I believe that
it would end up being a lot of work.  I wonder how often it would be
used if it was fully supported.  Probably not enough to be a priority.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090608/9efdd18e/attachment.sig>
