valgrind creeping into makefiles
Dima Karpeyev karpeev at gmail.com
Sat Aug 22 00:44:16 CDT 2009
I have one comment: "valgrind" sounds like a very tool-specific option.
Are there other memory checking tools?
Maybe there should be an option like "-memcheck [valgrind]" with an optional
tool name,
similar to "-start_in_debugger [gdb]"?
Dmitry.
On Fri, Aug 21, 2009 at 4:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   I noticed valgrind commands creeping into PETSc example makefiles. I
> believe this is a terrible model and would like to remove them.
>   I've added support for calling valgrind correctly from linux or the Mac
> to $PETSC_DIR/bin/petscmpiexec as an optional first argument -valgrind.
> Thus you can call any PETSc program with valgrind using, for example,
> petscmpiexec -valgrind -n 2 ./ex1 -ksp_monitor
>   Now for makefile tests one can run, for example: make runex7
> MPEXEC="petscmpiexec -valgrind" and it will run the runex7 test under
> valgrind.
> Is this an acceptable replacement for having all the horrible redundant use
> of valgrind directly in the makefiles and do I have everyones permission to
> remove the use of valgrind from the makefiles? If not, what support do I
> need to add to get rid of the use of valgrind from the makefiles?
>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090822/2665cb0b/attachment.html>
