KSPSolve_CG
Santolo Felaco ahuramazda10 at gmail.com
Thu Nov 27 13:30:55 CST 2008
Lisandro, I have sent the message on your personal email.
Bye
2008/11/26 Barry Smith <bsmith at mcs.anl.gov>
>  KSPSolve() calls KSPSolve_CG().
>   You can answer this type of question by using the option
> -start_in_debugger then
> in the debugger doing break KSPSolve_CG ; cont then when it stops
> in the KSPSolve_CG do a where.
>   Barry
> On Nov 26, 2008, at 2:28 PM, Santolo Felaco wrote:
>  Hi, I have to modified the KSPSolve_CG.  Want to know what is the function
>> that calls this routine. Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20081127/27e93ea5/attachment.html>
