KSPSolve_CG
Wed Nov 26 15:35:59 CST 2008
   KSPSolve() calls KSPSolve_CG().
    You can answer this type of question by using the option -
start_in_debugger then
in the debugger doing break KSPSolve_CG ; cont then when it stops
in the KSPSolve_CG do a where.
    Barry
On Nov 26, 2008, at 2:28 PM, Santolo Felaco wrote:
> Hi, I have to modified the KSPSolve_CG.  Want to know what is the
> function that calls this routine. Thanks
