about viewer formats
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 3 13:36:12 CST 2008
On Mon, Nov 3, 2008 at 2:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Done and pushed.
OK. Many thanks,
> I guess at one time we had it in our heads that NO format names would be
> shared among different
> viewers, but now I don't see why some basic ones cannot be shared.
BTW, Does it make sense to require the type_name being already set (I
mean, using the PetscValidType macro) before setting the format?
> On Nov 3, 2008, at 7:50 AM, Lisandro Dalcin wrote:
>> Barry, I saw you commit removing PETSC_VIEWER_BINARY_NATIVE. This
>> makes me think that PETSC_VIEWER_ASCII_DEFAULT and
>> PETSC_VIEWER_BINARY_DEFAULT (which is NOT used in sources) are a bit
>> redundat, Why not to remove both and add a new PETSC_VIEWER_DEFAULT?
>> Does it make sense?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
