blocked index sets
Wed Aug 27 14:10:16 CDT 2008
On Aug 27, 2008, at 1:34 PM, Dmitry Karpeev wrote:
> I would say that IS appears to be a *non-scalable* parallel object,
> since the only parallel call
> available for it seems to be ISAllGather (and variants).
    Yes this is non-scalable. Vecs have some nonscalable stuff in them
also.
> It also seems to me that the real use for an IS is as input to the
> ISLocalToGlobalMapping routines and it is
> the mapping object that is truly global.
    Actually they were created for VecScatterCreate() and
MatGetSubMatrices(), in both these cases
it is natural to think of the IS as a parallel object (though I agree
you can also think of it as not
a parallel object). For ISLocalToGlobalMapping() create, I agree there
is nothing that would make one
demand that the IS is parallel.
> As a test for IS being global, can one imagine a circumstance when
> the same IS
> can be used with two different mappings which carry different comms?
    I don't understand this test. On the processes that are in both
comms you could use
the same (sequential) IS, for example, to create a VecScatter.
Possible  but unliikely.
    Even if an object (class) has NO collective operations, if, when
you use that object, you must have partners are all
other processes in a MPI_Comm then I think it is a good approach to
have that be a parallel
object that shares the comm.
   Barry
> I also want to point out that, in retrospect, Sieve is an evolution
> of the IS/ISLocalToGlobalMapping
> set of ideas.
> Dmitry.
> On Wed, Aug 27, 2008 at 1:16 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> On Wed, Aug 27, 2008 at 1:08 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > On Aug 27, 2008, at 12:13 PM, Matthew Knepley wrote:
> >> On Wed, Aug 27, 2008 at 12:06 PM, Lisandro Dalcin <dalcinl at gmail.com
> >> wrote:
> >>> So, Do all us agree my proposed fix should be pushed? I'll wait
> for
> >>> Matt comments/complaints...
> >> I complain that IS is a fake parallel object.
> >  In what way is IS a fake parallel object? Maybe we can resolve
> > your concern about it being a fake parallel object.
> I said fake because it has a single collective operation (or even one
> with communication).
> We even use IS in situations where GetSize() makes no sense, or at
> least are not
> careful about the comm used. Also, none of the other functions work
> over the comm.
> For instance, the ISIsPermutation() or ISSorted() do not look at the
> indices collectively.
>  Matt
> >   Barry
> >> However, if
> >> GetSize/GetLocalSize already
> >> do this, then yes we should change the ISBlock version as well.
> >>  Matt
> >>> On Wed, Aug 27, 2008 at 1:13 PM, Barry Smith
> <bsmith at mcs.anl.gov> wrote:
> >>>> On Aug 27, 2008, at 10:23 AM, Matthew Knepley wrote:
> >>>>> There is no concept of global for IS. They are purely serial.
> AO is the
> >>>>> only
> >>>>> global construct with indices.
> >>>>  This is kind of true, and maybe used to be completely true.
> But IS does
> >>>> have a communicator and that communicator can be MPI_COMM_WORLD
> or
> >>>> any parallel communicator.  In other words the IS is evolving
> to be an
> >>>> object
> >>>> that can be parallel in the same sense as vecs or mats
> >>>>  There are already ISGetSize() and ISGetLocalSize() so it sure
> makes
> >>>> sense
> >>>> to have the same paradgm for the ISGetBlockSize().
> >>>>  Barry
> >>>> Originally IS had no parallel concept, then we added the
> >>>> ISGetSize/LocalSize
> >>>> but forgot to do it for the ISBlock...
> >>>>> Matt
> >>>>> On Wed, Aug 27, 2008 at 10:09 AM, Lisandro Dalcin <dalcinl at gmail.com
> >>>>> wrote:
> >>>>>> I believe we have to review the interface of ISBlock.
> Currently,
> >>>>>> ISBlockGetSize() return the number of LOCAL block indices.
> This is not
> >>>>>> consistent with other naming conventions for getting local
> and glocal
> >>>>>> sizes. I propose to change this to the following
> >>>>>> 1) change: ISBlockGetSize() returns the number global blocks
> >>>>>> 2) addition:  ISBlockGetLocalSize() return the number of
> local blocks
> >>>>>> Comments?
> >>>>>> Lisandro Dalcín
> >>>>>> Centro Internacional de Métodos Computacionales en Ingeniería
> (CIMEC)
> >>>>>> Instituto de Desarrollo Tecnológico para la Industria Química
> (INTEC)
> >>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas
> (CONICET)
> >>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> >>>>>> Tel/Fax: +54-(0)342-451.1594
> >>>>> What most experimenters take for granted before they begin their
> >>>>> experiments is infinitely more interesting than any results to
> which
> >>>>> their experiments lead.
> >>>>> -- Norbert Wiener
> >>> Lisandro Dalcín
> (CIMEC)
> (INTEC)
> (CONICET)
> which
> >> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
