Is c2html a required external package?
Fri Aug 8 12:58:02 CDT 2008
   If IBM compilers cannot compile c2html then they are buggy. c2html
is simple straightforward C code.
Let's see what is going wrong.
    Barry
On Aug 8, 2008, at 8:49 AM, Satish Balay wrote:
> I suspect c2html does not compile with IBM compilers. We should
> support --with-c2html=0 option.
> Satish
> On Fri, 8 Aug 2008, Matthew Knepley wrote:
>> On Fri, Aug 8, 2008 at 12:09 AM, Shi Jin <jinzishuai at yahoo.com>
>> wrote:
>>> Hi there,
>>> I was trying to build petsc-dev on a IBM AIX but failed at c2html.
>>> I tried not to use it with --with-c2html=0 but it seemed still be
>>> needed. Why do we need it? I don't need to generate documentations
>>> for this test.
>>> Thanks.
>> It is for documentation, but we do not consider an installation with
>> broken documentation fully functional. Can you send
>> the configure.log?
>>  Thanks,
>>     Matt
>>> Shi
>>> Shi Jin, PhD
