Is c2html a required external package?
Fri Aug 8 08:49:23 CDT 2008
I suspect c2html does not compile with IBM compilers. We should
support --with-c2html=0 option.
Satish
On Fri, 8 Aug 2008, Matthew Knepley wrote:
> On Fri, Aug 8, 2008 at 12:09 AM, Shi Jin <jinzishuai at yahoo.com> wrote:
> > Hi there,
> > I was trying to build petsc-dev on a IBM AIX but failed at c2html. I tried not to use it with --with-c2html=0 but it seemed still be needed. Why do we need it? I don't need to generate documentations for this test.
> > Thanks.
> It is for documentation, but we do not consider an installation with
> broken documentation fully functional. Can you send
> the configure.log?
>   Thanks,
>      Matt
> > Shi
> > Shi Jin, PhD
