New approach for external direct solvers in PETSc
Thu Aug 7 15:05:14 CDT 2008
On Jul 25, 2008, at 5:47 PM, Lisandro Dalcin wrote:
> BTW, Have you ever considered the posibility of not using the 'Mat'
> class for factored matrices?? I believe that normal matrices and
> factored matrices share very few in common as to being instances of
> the same class. Looking at the source code in src/mat, there are many
> checks like 'if (mat-->factor)' or  'if (!mat->factor)' that seems to
> support my concern. What do you think?
    After a (tiny) bit more thought I think we really should make this
change:
pros
1) it will simplify the code a good amount hence less bugs
2) conceptually it makes sense
cons
1) requires a large reorganization of the Mat code (will introduce bugs)
2) requires the user to deal with one more PETSc object (MatFactor)
      But since most users deal with SNES/KSP/PC most users will
      never see this new object.
   The question is when/how to make this massive change. It is as big
or bigger than the change I already made with MatGetFactor().
    Barry
> On Fri, Jul 25, 2008 at 7:02 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>  petsc-dev users,
>>    I have finally completed my changes to PETSc for a new approach to
>> accessing external direct solvers
>> in PETSc like Spooles, MUMPS etc. I will be pushing it to petsc-dev
>> sometime
>> the middle of next week.
>> If you are using the direct solvers you might consider cloning from
>> http://petsc.cs.iit.edu/hg/petsc/petsc-dev-new-solvers  or
>> ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev-new-solvers
>> and trying it out before then. Please report problem to
>> petsc-maint at mcs.anl.gov as you hit them.
>>  Barry
>> From the changes file
>> The "parallel direct solver" matrix types like
>> MATAIJSPOOLES are ALL gone. Now you use -pc_factor_mat_solver_package
>> spooles etc or PCFactorSetMatSolverPackage() or if working directly
>> with
>> matrices, MatGetFactor(A,MATSPOOLES,...)
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
