error building shared libs
Lisandro Dalcin dalcinl at gmail.com
Tue Apr 1 10:13:02 CDT 2008
I got this, no time to figure out what's going on. BTW, I manually did
'make allfortranstubs' before configure and build, just in case.
Completed building libraries
making shared libraries in /u/dalcinl/Devel/PETSc/petsc-dev/linux-gnu/lib
building libpetsc.so
building libpetscvec.so
building libpetscmat.so
building libpetscdm.so
zfddaf.o: In function `dmgetmatrix_':
/u/dalcinl/Devel/PETSc/petsc-dev/src/dm/da/utils/ftn-custom/zfddaf.c:51:
multiple definition of `dmgetmatrix_'
dmf.o:/u/dalcinl/Devel/PETSc/petsc-dev/src/dm/da/utils/ftn-auto/dmf.c:137:
first defined here
/usr/bin/ld: Warning: size of symbol `dmgetmatrix_' changed from 62 in
dmf.o to 351 in zfddaf.o
collect2: ld returned 1 exit status
make[2]: [shared_linux] Error 1 (ignored)
building libpetscksp.so
building libpetscsnes.so
building libpetscts.so
building libpetsccontrib.so
  Error during compile, check linux-gnu/conf/make.log
  Send it and linux-gnu/conf/configure.log to petsc-maint at mcs.anl.gov
make: [all] Error 1 (ignored)
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
