[PETSC #16801] petsc-dev make test breaks with 2 processes?
Wed Sep 26 09:06:22 CDT 2007
I pushed a fix.
 Matt
On 9/26/07, Matthew Knepley <petsc-maint at mcs.anl.gov> wrote:
> Cool, I can reproduce the failure. Satish just put code in to check this, so
> the error makes sense. I will find it after my run.
>   Matt
> On 9/25/07, mspieg <mspieg at ldeo.columbia.edu> wrote:
> > Hi all,
> >    I just pulled, reconfigured and rebuilt petsc-dev (changeset:
> > 11135:7c2e5fab809d) and the 2 processor test failed with an error from
> > PetscLogFlops (see error message below).  The same configuration file works
> > fine in the the latest release 2.3.3-p6.  Not immediately critical, but I
> > need petsc-dev for the PCDMMGDM routines (of which I'm still tracking down a
> > pernicous bug, but am getting close).
> > All help greatly appreciated
> > cheers
> > marc
> > p.s. system is MacOSX 10.4.10, mpich2-1.0.5p4
> > -------------output of make test----------------------
> > Running test examples to verify correct installation
> > C/C++ example src/snes/examples/tutorials/ex19 run
> > successfully with 1 MPI process
> > Possible error running C/C++
> > src/snes/examples/tutorials/ex19 with 2 MPI processes
> > See
> > http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> > lid velocity = 0.0016, prandtl # = 1, grashof # = 1
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Argument out of range!
> > [0]PETSC ERROR: PetscLogFlops: flop-count given is neagitive: -32.00!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Development Version 2.3.3, Patch 6, unknown HG
> > revision: unknown
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex19 on a macosx-gn named mingus.home by mspieg Tue Sep 25
> > 23:34:58 2007
> > [0]PETSC ERROR: Libraries linked from
> > /Applications/petsc/petsc-dev/lib
> > [0]PETSC ERROR: Configure run at Tue Sep 25 23:12:21 2007
> > [0]PETSC ERROR: Configure options CC=gcc FC=gfortran --with-python
> > --with-shared=1 --with-dynamic=1
> > --with-mpi-dir=/Applications/mpich/mpich2-1.0.5p4 --do
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Argument out of range!
> > [1]PETSC ERROR: PetscLogFlops: flop-count given is neagitive: -84.00!
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: Petsc Development Version 2.3.3, Patch 6, unknown HG
> > revision: unknown
> > [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [1]PETSC ERROR: See docs/index.html for manual pages.
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: ./ex19 on a macosx-gn named mingus.home by mspieg Tue Sep 25
> > 23:34:58 2007
> > [1]PETSC ERROR: Libraries linked from
> > [1]PETSC ERROR: Configure run at Tue Sep 25 23:12:21 2007
> > [1]PETSC ERROR: Configure options CC=gcc FC=gfortran --with-python
> > --download-mpich-pm=gforker --with-debugging=1 PETSC_ARCH=macosx-gnu-local-g
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: MatMultAdd_SeqMAIJ_4() line 585 in src/mat/impls/maij/maij.c
> > [0]PETSC ERROR: MatMult_MPIMAIJ_dof() line 2118 in src/mat/impls/maij/maij.c
> > [0]PETSC ERROR: MatMult() line 1670 in src/mat/interface/matrix.c
> > [0]PETSC ERROR: MatInterpolate() line 5925 in src/mat/interface/matrix.c
> > [0]PETSC ERROR: PCMGFCycle_Private() line 28 in src/ksp/pc/impls/mg/fmg.c
> > [0]PETSC ERROR: PCApply_MG() line 207 in src/ksp/pc/impls/mg/mg.c
> > [0]PETSC ERROR: PCApply() line 356 in src/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: FGMREScycle() line 232 in
> > src/ksp/ksp/impls/gmres/fgmres/fgmres.c
> > [0]PETSC ERROR: KSPSolve_FGMRES() line 358 in
> > [0]PETSC ERROR: KSPSolve() line 378 in src/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: SNES_KSPSolve() line 2539 in src/snes/interface/snes.c
> > [0]PETSC ERROR: SNESSolve_LS() line 184 in
> > src/snes/wnload-mpich-pm=gforker --with-debugging=1
> > [1]PETSC ERROR:
> > [1]PETSC ERROR: MatMultAdd_SeqMAIJ_4() line 585 in src/mat/impls/maij/maij.c
> > [1]PETSC ERROR: MatMult_MPIMAIJ_dof() line 2118 in src/mat/impls/maij/maij.c
> > [1]PETSC ERROR: MatMult() line 1670 in src/mat/interface/matrix.c
> > [1]PETSC ERROR: MatInterpolate() line 5925 in src/mat/interface/matrix.c
> > [1]PETSC ERROR: PCMGFCycle_Private() line 28 in src/ksp/pc/impls/mg/fmg.c
> > [1]PETSC ERROR: PCApply_MG() line 207 in src/ksp/pc/impls/mg/mg.c
> > [1]PETSC ERROR: PCApply() line 356 in src/ksp/pc/interface/precon.c
> > [1]PETSC ERROR: FGMREScycle() line 232 in
> > [1]PETSC ERROR: KSPSolve_FGMRES() line 358 in
> > [1]PETSC ERROR: KSPSolve() line 378 in src/ksp/ksp/interface/itfunc.c
> > [1]PETSC ERROR: SNES_KSPSolve() line 2539 in src/snes/interface/snes.c
> > [1]PETSC ERROR: SNESSolve_LS() line 184 in src/snes/impls/ls/ls.c
> > [0]PETSC ERROR: SNESSolve() line 1867 in src/snes/interface/snes.c
> > [0]PETSC ERROR: DMMGSolveSNES() line 510 in src/snes/utils/damgsnes.c
> > [0]PETSC ERROR: DMMGSolve() line 393 in src/snes/utils/damg.c
> > [0]PETSC ERROR: main() line 154 in
> > src/snes/examples/tutorials/ex19.c
> > [cli_0]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
> > impls/ls/ls.c
> > [1]PETSC ERROR: SNESSolve() line 1867 in src/snes/interface/snes.c
> > [1]PETSC ERROR: DMMGSolveSNES() line 510 in src/snes/utils/damgsnes.c
> > [1]PETSC ERROR: DMMGSolve() line 393 in src/snes/utils/damg.c
> > [1]PETSC ERROR: main() line 154 in
> > [cli_1]: aborting job:
> > application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
> > Graphics example src/snes/examples/tutorials/ex19 run
> > Fortran example src/snes/examples/tutorials/ex5f run
> > Completed test examples
> > Marc Spiegelman
> > Lamont-Doherty Earth Observatory
> > Dept. of Applied Physics/Applied Math
> > Columbia University
> > http://www.ldeo.columbia.edu/~mspieg
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
-- Norbert Wiener
