Compiling on Solaris 10 for X86
Adam Zhang Adam.Zhang at Sun.COM
Thu May 10 10:20:05 CDT 2007
Thank you for input. I will try to use gmake later.
If this compilation is ok. can I release this as a Solaris package on
the internet?
Adam
Matthew Knepley wrote:
> Nothing is wrong with the PETSc build or libraries. However, your make
> (probably not gmake) has a problem with the make rule that cleans up
> files
> in bmake/common/rules:359. You can just ignore it (or tell us what is
> wrong).
>  Thanks,
>     Matt
> On 5/10/07, Yi-Feng Adam Zhang <Adam.Zhang at sun.com> wrote:
>> Hi all,
>> Recently I am compiling the PETSc 2.3.2 -P10 on Solaris 10 for X86 with
>> GCC and Sun's f90.
>> Here is the command I give to configure.py:
>> ./config/configure.py --download-f-blas-lapack=1 --with-mpi=0
>> Yes. I don't use the MPI intendedly.  Because I want to make sure every
>> thing is ok before using MPI.
>> When I input the command "make all", every  thing looks fine.
>> But when I try to use "make test" to verify, I get the following error:
>> -bash-3.00# more test_log_solaris2.10-c-debug
>> Running test examples to verify correct installation
>> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>> MPI process
>> Graphics example src/snes/examples/tutorials/ex19 run successfully with
>> 1 MPI process
>> sh: test: argument expected
>> *** Error code 1 (ignored)
>> The following command caused the error:
>> if test -e ex19.exe; then /usr/bin/rm -f ex19.exe; fi
>> if test -e ex19.ilk; then /usr/bin/rm -f ex19.ilk; fi
>> if test -e ex19.pdb; then /usr/bin/rm -f ex19.pdb; fi
>> if test -e ex19.tds; then /usr/bin/rm -f ex19.tds; fi
>> Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
>> MPI process
>> if test -e ex5f.exe; then /usr/bin/rm -f ex5f.exe; fi
>> if test -e ex5f.ilk; then /usr/bin/rm -f ex5f.ilk; fi
>> if test -e ex5f.pdb; then /usr/bin/rm -f ex5f.pdb; fi
>> if test -e ex5f.tds; then /usr/bin/rm -f ex5f.tds; fi
>> Completed test examples
>> Does anyone have any suggestion?  Thanks in advance!
>> Regards,
>> Adam
