Compiling on Solaris 10 for X86
Thu May 10 07:54:20 CDT 2007
Nothing is wrong with the PETSc build or libraries. However, your make
(probably not gmake) has a problem with the make rule that cleans up files
in bmake/common/rules:359. You can just ignore it (or tell us what is wrong).
     Matt
On 5/10/07, Yi-Feng Adam Zhang <Adam.Zhang at sun.com> wrote:
> Hi all,
> Recently I am compiling the PETSc 2.3.2 -P10 on Solaris 10 for X86 with
> GCC and Sun's f90.
> Here is the command I give to configure.py:
> ./config/configure.py --download-f-blas-lapack=1 --with-mpi=0
> Yes. I don't use the MPI intendedly.  Because I want to make sure every
> thing is ok before using MPI.
> When I input the command "make all", every  thing looks fine.
> But when I try to use "make test" to verify, I get the following error:
> -bash-3.00# more test_log_solaris2.10-c-debug
> Running test examples to verify correct installation
> C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> MPI process
> Graphics example src/snes/examples/tutorials/ex19 run successfully with
> 1 MPI process
> sh: test: argument expected
> *** Error code 1 (ignored)
> The following command caused the error:
> if test -e ex19.exe; then /usr/bin/rm -f ex19.exe; fi
> if test -e ex19.ilk; then /usr/bin/rm -f ex19.ilk; fi
> if test -e ex19.pdb; then /usr/bin/rm -f ex19.pdb; fi
> if test -e ex19.tds; then /usr/bin/rm -f ex19.tds; fi
> Fortran example src/snes/examples/tutorials/ex5f run successfully with 1
> MPI process
> if test -e ex5f.exe; then /usr/bin/rm -f ex5f.exe; fi
> if test -e ex5f.ilk; then /usr/bin/rm -f ex5f.ilk; fi
> if test -e ex5f.pdb; then /usr/bin/rm -f ex5f.pdb; fi
> if test -e ex5f.tds; then /usr/bin/rm -f ex5f.tds; fi
> Completed test examples
> Does anyone have any suggestion?  Thanks in advance!
> Regards,
> Adam
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
