configuration problem and patch
Thu Jun 21 17:18:12 CDT 2007
Cool, I will apply it.
   Matt
On 6/21/07, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Barry, I had problems configuring a fresh clone of petsc-dev, you have
> attached a patch with solved it for me. As new build systems is rather
> new for me, please review it and apply it (if it is OK)
> BTW, if things works as I understood, perhaps the those small files
> saved in packageDir should be prefixed and posfixed with the
> PETSC_ARCH used in configuration (let say, using perhaps somethink
> like petsc-hypre.linux-gnu, petsc-ml.linux-gnu).
> Regards,
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
