configuration problem and patch
Lisandro Dalcin dalcinl at gmail.com
Thu Jun 21 11:28:45 CDT 2007
Barry, I had problems configuring a fresh clone of petsc-dev, you have
attached a patch with solved it for me. As new build systems is rather
new for me, please review it and apply it (if it is OK)
BTW, if things works as I understood, perhaps the those small files
saved in packageDir should be prefixed and posfixed with the
PETSC_ARCH used in configuration (let say, using perhaps somethink
like petsc-hypre.linux-gnu, petsc-ml.linux-gnu).
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20070621/fa7cc06f/attachment.bin>
