update to BuildSystem-dev for parmetis on Apple
Victor Eijkhout eijkhout at tacc.utexas.edu
Sun Jan 28 22:45:21 CST 2007
On Jan 28, 2007, at 1:12 PM, Satish Balay wrote:
> Are you sure you have the correct sources? I don't get
> such errors with current petsc-dev
> Things to check. [with both petsc-dev & BuildSystem]
> - do you have any edited fies?
> hg status
> - did you update the sources after pull?
> hg update
> If you have no local edits - then use the following to
> make sure the workingdir sources are uptodate
> cd petsc-dev
> make pull PETSC_ARCH=docsonly
[albook:~/Software/petsc/petsc-dev] %% hg status
? 1
[albook:~/Software/petsc/petsc-dev] %% less ../Makefile
[albook:~/Software/petsc/petsc-dev] %% hg update
0 files updated, 0 files merged, 0 files removed, 0 files unresolved
[albook:~/Software/petsc/petsc-dev] %% (cd python/BuildSystem/ ; hg
update)
[albook:~/Software/petsc/petsc-dev] %% make pull PETSC_ARCH=docsonly
pulling from http://mercurial.mcs.anl.gov/petsc/petsc-dev
searching for changes
no changes found
pulling from http://mercurial.mcs.anl.gov/petsc/BuildSystem
no changes found
Anyway, fresh clone and it worked.
Victor.
> Satish
> On Sun, 28 Jan 2007, Victor Eijkhout wrote:
>> No module named Fiat.
>> I did a pull of the source and buildsystem.
>> Victor.
Victor Eijkhout, 512 471 5809 (w), 512 499 0504 (h)
Texas Advanced Computing Center, The University of Texas at Austin
