update to BuildSystem-dev for parmetis on Apple
Sun Jan 28 13:12:38 CST 2007
Are you sure you have the correct sources? I don't get
such errors with current petsc-dev
Things to check. [with both petsc-dev & BuildSystem]
- do you have any edited fies?
hg status
- did you update the sources after pull?
hg update
If you have no local edits - then use the following to
make sure the workingdir sources are uptodate
cd petsc-dev
make pull PETSC_ARCH=docsonly
Satish
On Sun, 28 Jan 2007, Victor Eijkhout wrote:
> No module named Fiat.
> I did a pull of the source and buildsystem.
> Victor.
