more configure....
Boyana Norris norris at mcs.anl.gov
Tue Apr 19 16:23:56 CDT 2005
First, thanks for the lightning fast response to my first petsc-dev question
(or is it negative time, since Matt had already implemented what I asked for
last night).
My next configure wish list thing is to have a way to "restart" configure
from a certain point. This is probably a bit tricky to implement. The syntax
I am thinking of (and there may be better options) would be to have a
--resume or --continue option given to configure, in addition to new or
modified options. Then, it would restart from the "right" place, given the
new set of options, while avoiding redundant checks. For example, if there
was a bad mpi path given to petsc's configure, I would like to be able to
rerun it with a corrected mpi location (everything else staying the same)
and avoid rerunning all the other unrelated configuration checks that happen
to come before it. Obviously this saves a lot of time for failures that
occur near the end of configure. This is not like gnu configure's caching,
which doesn't really work anyway.
I'm not sure there is enough infrastructure right now to implement something
like this; for example, the dependencies between various configure options
are not apparent. I don't think, however, that a completely general solution
is essential -- even something as simple as restarting at the last error
would be great. In any case I think this would be a "use at your own risk"
option since there will always be the fallback full rerun of configure.
Boyana
