configure options
Tue Apr 19 14:29:48 CDT 2005
On Tue, 19 Apr 2005, Boyana Norris wrote:
> Satish,
> Thanks, this is sufficient for most cases (the only exception I can think of
> is when configure crashed or was interrupted before this file was created,
> which has happened to me a few times).
If thats the case - you have shell command history :)
But Matt is adding the extra dump to configure.log - suitable for
copy/paste with shell.
And I'm refining the python side of things a bit. i.e the following
should work:
 "Command line options should take precedence over predefined values
in the script."
For eg: I could have:
config/configure.py --with-mpi-dir=/home/balay/mpich-1 -PETSC_ARCH=arch1
Now I should be able to do:
./bmake/arch1/configure.py --with-mpi-dir=/home/balay/mpich-2 -PETSC_ARCH=arch2
Satish
