[petsc-announce] petsc-3.7.3.tar.gz now available
    Satish Balay
    balay at mcs.anl.gov
    Sun Jul 24 13:44:41 CDT 2016
Dear PETSc users,
The patch release petsc-3.7.3 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
 * Vec: enable Fortran interfaces for VecGetLocalVectorRead(), VecRestoreLocalVectorRead()
 * Vec: enable Fortran interfaces for VecGetLocalVector(), VecRestoreLocalVector()
 * Mat: fix MatShift() bug when shift operation has not been provided
 * PCBDDC: fix for getri error -2 with MKL
 * SNES: Only apply the SNES QN Powell condition after the first full iteration of L-BFGS
 * Monitor: -xxx_monitor would result in multiple output of the same data if xxxSetFromOptions() was called multiple times
 * DMP4est: in setup, coordDM needs the pointSF, too.
 * Fortran: enable stub for MatCreateRedundantMatrix()
 * Mat: Fix bugs in MatGetRowIJ_SeqBAIJ() and MatGetRowIJ_SeqSBAIJ()
 * IS: added missing Fortran stubs ISGetTotalIndices(), ISRestoreTotalIndices(), ISGetNonlocalIndices(), ISRestoreNonlocalIndices()
 * Mat: Added MatFDColoringSetType()
 * TS: Set default TSAdaptType at creation
 * Mat: enable fortran stubs for MatCreateComposite(), MatCompositeSetType()
 * Superlu/Superlu_DIST: update to latest maint snapshot
 * KSP: fix KSPSetNormType(ksp,KSP_NORM_NONE)
 * TS: Run forward cost integral after event handling if step not rolled back
 * Fixed a variety of issues related to iOS builds
 * ML: update to use a snapshot with a build fix for --with-fc=0 [aka Mac]
 * HYPRE: update to 2.11.1 release from RC
 * PetscSF: Recursively unwrap dupped types
Satish
More information about the petsc-announce
