[petsc-announce] petsc-3.7.2.tar.gz now available
Sun Jun 5 13:06:04 CDT 2016
Dear PETSc users,
The patch release petsc-3.7.2 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
 * Hypre: Updated to use latest test release v2.11.0-47-gbba1cfc
 * XSDK: fix configure when using --download-trilinos-cmake-arguments with --download-xsdk
 * MPIUNI: Fix error when creating additional MPI communicators
 * MUMPS: Add support for --download-mumps with --with-mumps-serial and MPIUni
 * Configure: do not pass visibility flags [via CFLAGS/CXXFLAGS] to externalpackage builds
 * Mat: fix bug in MatGetFactor()
 * Mat: fix big in MatGetRowIJ_SeqAIJ_Inode*()
 * Sys: add in PETSCRANDER48 to finclude
 * Sys: add missing fortran stub for PetscRandomGetType()
 * Sys: PetscViewerBinaryRead() only set the count value if MPI IO was used
 * Chombo: use updated tarball that compiles with gcc-6.1
 * DMPlex: Choose default partitioner from [chaco, parmetis, simple]
 * petsc4py: update to use latest maint/3.7 snapshot
 * configure: fix slowdown during --download-hdf5 with gcc-5
 * Superlu_DIST: disable OpenMP [that can come in future patch fixes..]
 * XSDK: Explicitly turn off Fortran for Trilinos and xSDKTrilinos when turned off for PETSc
 * Sys: make sure the MPI_Datatype used corresponds to the PETSc datatype used. [wrt MPI_INT64_T vs MPI_LONG_LONG_INT]
 * SuperLU_Dist: Specifically turn off Fortran for SuperLU_Dist if PETSc is built without it
 * TS: Need to declare TSSSPList as PETSC_EXTERN so users can add to the list
 * DMP4est: fix coarseEdge calculation in transfer_Point
 * Fortran: add missing PETSC_EXTERN to custom Fortran wrappers
 * Fortran: fix typo with PETSCVIEWERASCIIPUSHSYNCHRONIZED and PETSCVIEWERASCIIPOPSYNCHRONIZED
 * PC: Added PCPreSolveChangeRHS()
 * XSDK: fix mstk shared library build
 * Vec: disable buggy VecAssemblyBegin/End_MPI_BTS()
Satish
More information about the petsc-announce mailing list
