performance issue
Jim Edwards jedwards at ucar.edu
Thu Aug 10 12:01:52 CDT 2023
On Thu, Aug 10, 2023 at 10:53 AM Wei-Keng Liao <wkliao at northwestern.edu>
wrote:
> From the file header dump you sent earlier, no PnetCDF hint is necessary.
> What MPI-IO hints are you using?
I am now using:
MPICH_MPIIO_HINTS=*:romio_cb_read=enable:romio_cb_write=enable:striping_factor=48:striping_unit=134217728
we explored the parameter space and this seems to be about the best for
this particular file.   But I think that there is still something
wrong at a low level and am working on trying to figure that out.
> One question. Did you delete the output file before each run?
> Yes
> Wei-keng
> On Aug 10, 2023, at 11:35 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> We are having a lot of problems with darshan on our system - I'm working
> with the darshan developers to resolve.
> I am setting MPIIO hints - but I see that there are some hints specific to
> pnetcdf - do you have any recommendations?
> On Thu, Aug 10, 2023 at 10:15 AM Wei-Keng Liao <wkliao at northwestern.edu>
> wrote:
>> Hi, Jim
>> FYI. Darshan now can capture the I/O activities of PnetCDF,
>> in addition to the already MPI-IO and POSIX-IO.
>> Wei-keng
>> On Aug 9, 2023, at 6:22 PM, Wei-Keng Liao <wkliao at northwestern.edu>
>> wrote:
>> In that case, I have the E3SM-IO benchmark that has a fairly complicate
>> I/O
>> partitioning pattern. It used the decomposition maps generated from PIO.
>> https://github.com/Parallel-NetCDF/E3SM-IO
>> <https://urldefense.com/v3/__https://github.com/Parallel-NetCDF/E3SM-IO__;!!Dq0X2DkFhyF93HkjWTBQKhk!UJAnknjDPQWY43szbAutlokjDrSHyBOcTlhEOChqYtThxnr812hxwvb8aSmHcEPiNOxNdOUHZi9Z2fyXbg2j6JH1HTo$>
>> Wei-keng
>> On Aug 9, 2023, at 6:17 PM, Jim Edwards <jedwards at ucar.edu> wrote:
>> I think that your example case is too simple - it's doing a simple block
>> decomposition.
>> In order to get the performance difference I am observing I need to do a
>> more complicated
>> mapping.   I will work on a program that reproduces the problem without
>> pio but it may take a
>> while.
> Jim Edwards
> CESM Software Engineer
> National Center for Atmospheric Research
> Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20230810/c2f2068d/attachment.html>
