performance issue
Wei-Keng Liao wkliao at northwestern.edu
Fri Aug 4 10:39:10 CDT 2023
Hi, Jim
Can your provide the test program and the file header dumped by "ncdump -h", if that is available?
Also, what machine was used in the tests and its the parallel file system configuration is?
These can help diagnose.
Wei-keng
On Aug 4, 2023, at 8:49 AM, Jim Edwards <jedwards at ucar.edu> wrote:
I am using ncmpi_iput_varn and ncmpi_wait_all to write output from my model.   I have a test program that does nothing but test the
performance of the write operation.   Attached is a plot of performance in the model and in the standalone application.   I'm looking for
clues as to why the model performance is scaling so badly with the number of variables but the standalone program performance is fine.
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
<Screenshot 2023-07-27 at 11.49.03 AM.png>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20230804/8e7d4805/attachment.html>
