nc-config
Nick Papior nickpapior at gmail.com
Tue Jan 26 09:08:31 CST 2016
nc-config is from netcdf source, it isn't part of the pnetcdf installation.
It says whether the netcdf is compiled _with_ pnetcdf support.
2016-01-26 0:33 GMT+01:00 Noel Keen <ndkeen at lbl.gov>:
> Hello,
> I'm working on a code which has a build system that is looking for
> nc-config to query about installation.
> For example:
> edison07% nc-config --has-dap
> no
> nc-config exists for serial netcdf install, but is nowhere to be found for
> the pnetcdf
> install.  Should it be there?  Is nc-config a part of parallel netcdf?
> I should installed pnetcdf 1.6.1 on local workstation and I can't a
> nc-config
> anywhere.  It would seem that nc-config would know about parallel builds
> as why is there a "nc-config --has-pnetcdf" ?
> Thanks
> Noel
Kind regards Nick
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20160126/79247536/attachment.html>
