nc-config
Noel Keen ndkeen at lbl.gov
Mon Jan 25 17:33:59 CST 2016
Hello,
I'm working on a code which has a build system that is looking for nc-config to query about installation.
For example:
edison07% nc-config --has-dap
no
nc-config exists for serial netcdf install, but is nowhere to be found for the pnetcdf
install.  Should it be there?  Is nc-config a part of parallel netcdf?
I should installed pnetcdf 1.6.1 on local workstation and I can't a nc-config
anywhere.  It would seem that nc-config would know about parallel builds
as why is there a "nc-config --has-pnetcdf" ?
Thanks
Noel
