error in installing Pnetcdf
Wei-keng Liao wkliao at eecs.northwestern.edu
Mon Jan 4 12:20:57 CST 2016
I can see from the first screen shot that "mpd" is required for running an MPI program on your system. In this case, please run command "mpdboot" before PnetCDF's "make ptests". Let me know if this solves the problem.
Wei-keng
On Dec 31, 2015, at 3:40 AM, phani sri wrote:
> Sir/ Mam, I am installing Pnetcdf-1.6.1, while installation, first it showed problem in configuring,  configure: error: F77 does not	support "integer*8" then after searching the http://lists.mcs.anl.gov/pipermail/parallel-netcdf/2011-June/001196.html, I made some changes to configure file, then it did not show any error while configuring but while make install and make check install it is showing the following errors. Please help me some way
> D.P.S.L.Kameswari,
> Ph.D(Physics)
> ACRHEM
> University Of Hyderabad,
> Hyderabad,
> e-mail:phanisri123 at gmail.com
> <pnet.jpeg><pnet1.jpeg><pnetcdf.jpeg><pnetcdf1.jpeg><pnetcdf2.jpeg>
