pnetcdf bug?
Bill Sacks wsacks at gmail.com
Wed Oct 28 07:05:45 CDT 2015
Hi Wei-keng,
Thank you very much for your work on this! I will send this along to the netcdf group.
Thank you,
Bill
> On Oct 27, 2015, at 4:29 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> Hi, Bill
> I confirm this is a bug in netCDF. Please go ahead submit a bug to the netCDF group.
> Below is the patch to fix this bug.
> % diff wkliao/libsrc/nc3internal.c ../netcdf-4.3.3.1/libsrc/nc3internal.c
> 213c213
> < 		        if ((*vpp)->begin < ncp->old->vars.value[j]->begin) {
> 218,219d217
> <                             index = (*vpp)->begin;
> I also wrote a short program (attached) that adds 2 new variables and tested
> it on your file created by PnetCDF method. I have to add a printf statement in
> netCDF library to print the variable offsets. See comments inside the test
> program. You can also send the codes to netCDF support.
> If you decide to apply the patch to your netCDF library, please let me know
> if it works for you.
> Wei-keng
> <add_var.c>
> On Oct 27, 2015, at 3:19 PM, Bill Sacks wrote:
>> Hi Wei-keng,
>> Thanks very much for looking into this. I'm happy to submit a bug to the netCDF group if you think that's the best next step.
>> Superficially, this sure sounds similar to https://bugtracking.unidata.ucar.edu/browse/NCF-234 – but maybe there are details that make it differ.
>> Thanks,
>> Bill
>>> On Oct 27, 2015, at 1:11 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>>> Hi, Bill
>>> I checked the file starting offsets for the two newly added variables.
>>> It appears that ncks (netCDF underneath) does not respect the offset
>>> alignment used in the files created by PnetCDF.
>>> Your file created by netCDF has no alignment in between two adjacent variables.
>>> The other file created by PnetCDF has an alignment of 512 bytes.
>>> So, when ncks adds 2 new variables, I found the file offsets of the
>>> two new variables overlap with the last variable of the existing file.
>>> This indicates a bug in netCDF library, as ncks does not use PnetCDF library.
>>> I will dig into netCDF library to see what happens internally.
>>> Wei-keng
>>> On Oct 27, 2015, at 1:41 PM, Bill Sacks wrote:
>>>> Looking back at my notes, it seems that this problem sometimes appears in differences in actual values – i.e., it doesn't appear to just be a difference in where there are fill values.
>>>> Thank you,
>>>> Bill
>>>>> On Oct 27, 2015, at 12:30 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>>>>> Hi, Bill
>>>>> I can reproduce what you are seeing.
>>>>> If the differences happen only to those missing array elements (fill values),
>>>>> then this is because PnetCDF supports the fill mode only in 1.6.1.
>>>>> Please note the way fill mode is used differs from netCDF. See the release note
>>>>> and example codes in
>>>>> http://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/ReleaseNotes-1.6.1
>>>>> Please let me know if this is the case.
>>>>> Wei-keng
>>>>> On Oct 27, 2015, at 12:41 PM, Bill Sacks wrote:
>>>>>> I have put the attachment on a public ftp server:
>>>>>> ftp ftp.cgd.ucar.edu
>>>>>> user name: anonymous
>>>>>> password: (your email address)
>>>>>> cd pub/sacks
>>>>>> get pnetcdf_bug.tar.gz
>>>>>> Thanks,
>>>>>> Bill
>>>>>>> On Oct 27, 2015, at 11:11 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>>>>>>> Hi, Bill
>>>>>>> Bug NCF-234 should not be the cause, as you are using netCDF 4.3.3.1.
>>>>>>> The fix has been applied to 4.3.0. I will take a look and get back to you.
>>>>>>> Somehow your attachment did not come through my mail system.
>>>>>>> I check PnetCDF mail archive and it does not appear there either.
>>>>>>> http://lists.mcs.anl.gov/pipermail/parallel-netcdf/2015-October/001746.html
>>>>>>> Maybe the file is too big? If that is the case, please send it to me directly.
>>>>>>> Thanks
>>>>>>> Wei-keng
>>>>>>> On Oct 27, 2015, at 10:36 AM, Bill Sacks wrote:
>>>>>>>> I wonder if this could be related to this (fixed) bug:
>>>>>>>> As with that one, it's possible that the problem is actually in netCDF and not in pnetcdf. Does anyone have an idea for how to determine if this is a pnetcdf problem or a netcdf problem? Or should I go ahead and post this to the netcdf bug list as well?
>>>>>>>> Charlie: I'm feeling more and more that NCO is probably off the hook here: sorry for dragging you into this initially :-)
>>>>>>>> Bill
>>>>>>>>> On Oct 27, 2015, at 9:21 AM, Bill Sacks <wsacks at gmail.com> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I have run into what appears to be a bug in pnetcdf: I have a file written by pnetcdf (via CESM). When I try to append a variable onto it using ncks -A, the new variable gets written properly, but a different variable on the file gets garbage values put into it. If the original file is written with standard netcdf rather than pnetcdf, the problem does not occur.
>>>>>>>>> I am attaching a tar file that contains files needed to see the problem. It contains two restart files written by CESM (file names beginning check_ncks...): one written with pnetcdf and one with standard netcdf (the latter has "netcdf" in its name). It also contains a third file from which I was trying to copy variables onto this file.
>>>>>>>>> To reproduce:
>>>>>>>>> cp check_ncks_problem_noInterp_1027.clm2.r.0001-01-01-01800.nc test.nc
>>>>>>>>> ncks -A -v COL_Z_p,LEVGRND_CLASS_p finidat_interp_dest.nc test.nc
>>>>>>>>> ncdump -v plant_nalloc check_ncks_problem_noInterp_1027.clm2.r.0001-01-01-01800.nc > dump1
>>>>>>>>> ncdump -v plant_nalloc test.nc > dump2
>>>>>>>>> diff dump1 dump2 | less
>>>>>>>>> Notice that many points that were FillValue have been replaced by garbage.
>>>>>>>>> If you do the same thing, but using check_ncks_problem_noInterp_netcdf_1027.clm2.r.0001-01-01-01800.nc, then the dumps are identical.
>>>>>>>>> I originally filed a bug report with NCO <https://sourceforge.net/p/nco/bugs/84/>, but Charlie Zender and Jim Edwards both feel that this is most likely a problem in the writing of the original file, which points to a possible pnetcdf problem.
>>>>>>>>> CESM was built with
>>>>>>>>>     module load netcdf-mpi/4.3.3.1
>>>>>>>>>     module load pnetcdf/1.6.0
>>>>>>>>> (on NCAR's yellowstone machine).
>>>>>>>>> Thank you,
>>>>>>>>> Bill
>>>>>>>>> Bill Sacks
>>>>>>>>> CESM Software Engineering Group
>>>>>>>>> National Center for Atmospheric Research
>>>>>>>>> (303) 497-1762
