pnetcdf bug?
Bill Sacks wsacks at gmail.com
Tue Oct 27 10:21:05 CDT 2015
I have run into what appears to be a bug in pnetcdf: I have a file written by pnetcdf (via CESM). When I try to append a variable onto it using ncks -A, the new variable gets written properly, but a different variable on the file gets garbage values put into it. If the original file is written with standard netcdf rather than pnetcdf, the problem does not occur.
I am attaching a tar file that contains files needed to see the problem. It contains two restart files written by CESM (file names beginning check_ncks...): one written with pnetcdf and one with standard netcdf (the latter has "netcdf" in its name). It also contains a third file from which I was trying to copy variables onto this file.
To reproduce:
cp check_ncks_problem_noInterp_1027.clm2.r.0001-01-01-01800.nc test.nc
ncks -A -v COL_Z_p,LEVGRND_CLASS_p finidat_interp_dest.nc test.nc
ncdump -v plant_nalloc check_ncks_problem_noInterp_1027.clm2.r.0001-01-01-01800.nc > dump1
ncdump -v plant_nalloc test.nc > dump2
diff dump1 dump2 | less
Notice that many points that were FillValue have been replaced by garbage.
If you do the same thing, but using check_ncks_problem_noInterp_netcdf_1027.clm2.r.0001-01-01-01800.nc, then the dumps are identical.
I originally filed a bug report with NCO <https://sourceforge.net/p/nco/bugs/84/ <https://sourceforge.net/p/nco/bugs/84/>>, but Charlie Zender and Jim Edwards both feel that this is most likely a problem in the writing of the original file, which points to a possible pnetcdf problem.
CESM was built with
        module load netcdf-mpi/4.3.3.1
        module load pnetcdf/1.6.0
(on NCAR's yellowstone machine).
Thank you,
Bill
Bill Sacks
CESM Software Engineering Group
National Center for Atmospheric Research
(303) 497-1762
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20151027/1feba765/attachment.html>
