pnetcdf bug?
Bill Sacks wsacks at gmail.com
Tue Oct 27 13:41:48 CDT 2015
Looking back at my notes, it seems that this problem sometimes appears in differences in actual values – i.e., it doesn't appear to just be a difference in where there are fill values.
Thank you,
Bill
> On Oct 27, 2015, at 12:30 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> Hi, Bill
> I can reproduce what you are seeing.
> If the differences happen only to those missing array elements (fill values),
> then this is because PnetCDF supports the fill mode only in 1.6.1.
> Please note the way fill mode is used differs from netCDF. See the release note
> and example codes in
> http://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/ReleaseNotes-1.6.1
> Please let me know if this is the case.
> Wei-keng
> On Oct 27, 2015, at 12:41 PM, Bill Sacks wrote:
>> I have put the attachment on a public ftp server:
>> ftp ftp.cgd.ucar.edu
>> user name: anonymous
>> password: (your email address)
>> cd pub/sacks
>> get pnetcdf_bug.tar.gz
>> Thanks,
>> Bill
>>> On Oct 27, 2015, at 11:11 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
>>> Hi, Bill
>>> Bug NCF-234 should not be the cause, as you are using netCDF 4.3.3.1.
>>> The fix has been applied to 4.3.0. I will take a look and get back to you.
>>> Somehow your attachment did not come through my mail system.
>>> I check PnetCDF mail archive and it does not appear there either.
>>> http://lists.mcs.anl.gov/pipermail/parallel-netcdf/2015-October/001746.html
>>> Maybe the file is too big? If that is the case, please send it to me directly.
>>> Thanks
>>> Wei-keng
>>> On Oct 27, 2015, at 10:36 AM, Bill Sacks wrote:
>>>> I wonder if this could be related to this (fixed) bug:
>>>> https://bugtracking.unidata.ucar.edu/browse/NCF-234
>>>> As with that one, it's possible that the problem is actually in netCDF and not in pnetcdf. Does anyone have an idea for how to determine if this is a pnetcdf problem or a netcdf problem? Or should I go ahead and post this to the netcdf bug list as well?
>>>> Charlie: I'm feeling more and more that NCO is probably off the hook here: sorry for dragging you into this initially :-)
>>>> Bill
>>>>> On Oct 27, 2015, at 9:21 AM, Bill Sacks <wsacks at gmail.com> wrote:
>>>>> Hi,
>>>>> I have run into what appears to be a bug in pnetcdf: I have a file written by pnetcdf (via CESM). When I try to append a variable onto it using ncks -A, the new variable gets written properly, but a different variable on the file gets garbage values put into it. If the original file is written with standard netcdf rather than pnetcdf, the problem does not occur.
>>>>> I am attaching a tar file that contains files needed to see the problem. It contains two restart files written by CESM (file names beginning check_ncks...): one written with pnetcdf and one with standard netcdf (the latter has "netcdf" in its name). It also contains a third file from which I was trying to copy variables onto this file.
>>>>> To reproduce:
>>>>> cp check_ncks_problem_noInterp_1027.clm2.r.0001-01-01-01800.nc test.nc
>>>>> ncks -A -v COL_Z_p,LEVGRND_CLASS_p finidat_interp_dest.nc test.nc
>>>>> ncdump -v plant_nalloc check_ncks_problem_noInterp_1027.clm2.r.0001-01-01-01800.nc > dump1
>>>>> ncdump -v plant_nalloc test.nc > dump2
>>>>> diff dump1 dump2 | less
>>>>> Notice that many points that were FillValue have been replaced by garbage.
>>>>> If you do the same thing, but using check_ncks_problem_noInterp_netcdf_1027.clm2.r.0001-01-01-01800.nc, then the dumps are identical.
>>>>> I originally filed a bug report with NCO <https://sourceforge.net/p/nco/bugs/84/>, but Charlie Zender and Jim Edwards both feel that this is most likely a problem in the writing of the original file, which points to a possible pnetcdf problem.
>>>>> CESM was built with
>>>>>       module load netcdf-mpi/4.3.3.1
>>>>>       module load pnetcdf/1.6.0
>>>>> (on NCAR's yellowstone machine).
>>>>> Thank you,
>>>>> Bill
>>>>> Bill Sacks
>>>>> CESM Software Engineering Group
>>>>> National Center for Atmospheric Research
>>>>> (303) 497-1762
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20151027/d4a4d1bc/attachment-0001.html>
