Using pnetcdf in WRF-Chem model: "DRYRUN" errors while creating wrf restart file
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Mar 12 17:17:39 CDT 2015
Hi, Zheng
At the end of that discussion thread, it was concluded that the latest version of WRF 3.6
solves the problem. Are you using 3.6?
Wei-keng
On Mar 12, 2015, at 3:49 PM, Zheng Lu wrote:
> Dear Pnetcdf group,
> I am running wrf model with pnetcdf option on NCAR supercomputer Yellowstone. Because my model simulation is very long, I have to use the “restart” option - which means that the model has to be shut down every 12 hours and be resubmitted. The model did successfully generate output files (15G) and restart files (106G). But after several resubmission (5 times), the model failed to generate restart files and reports many “DRYRUN” errors.
> The errors look like:
> d01 2014-09-07_06:00:00  Warning DRYRUN READ in wrf_io.F90, line        2996
> d01 2014-09-08_00:00:00  Warning 2 DRYRUNS 1 VARIABLE (LANDMASK) in wrf_io.F90, line        2403
> d01 2014-09-08_00:00:00  Warning 2 DRYRUNS 1 VARIABLE (XLAT) in wrf_io.F90, line        2403
> d01 2014-09-08_00:00:00  Warning 2 DRYRUNS 1 VARIABLE (XLONG) in wrf_io.F90, line        2403
> d01 2014-09-08_00:00:00  Warning 2 DRYRUNS 1 VARIABLE (LU_INDEX) in wrf_io.F90, line        2403
> After browsing this email list, I found one thread talking about the exactly same problem as I am having:
> http://lists.mcs.anl.gov/pipermail/parallel-netcdf/2014-June/001575.html
> I am wondering if anyone solve this problem?
> Thanks in advance!
> Zheng Lu
