trouble testing/running with gnu/5.1.0
Jim Edwards jedwards at ucar.edu
Mon Jul 20 13:53:16 CDT 2015
I think that you are correct I switched to pgi and got the same error -  I
can try on another platform.
The pgi config.log is attached...
On Mon, Jul 20, 2015 at 12:48 PM, Wei-keng Liao <
wkliao at eecs.northwestern.edu> wrote:
> Hi, Jim
> I suspect it is caused by an old MPI.
> Can you send me your config.log file?
> Wei-keng
> On Jul 20, 2015, at 12:36 PM, Jim Edwards wrote:
> > I am getting an error when trying to build with gnu/5.1.0
> > ​the traceback looks like:
> > #6  0x00000000014fb478 in ncmpii_in_swapn ()
> > #7  0x00000000014cd6be in ncmpii_getput_vars ()
> > #8  0x00000000014d9b64 in ncmpi_put_vara_int_all ()
> > #9  0x00000000014baf57 in nfmpi_put_vara_int_all_ ()
> > #10 0x00000000013f61e2 in __pionfput_mod_MOD_put_vara_1d_int ()
> > If I try to run the tests with this build I get a hang in the sequentiol
> tests:
> > poe  ./nc_test -v -d       .
> >    2:*** Testing test_ncmpi_strerror            ...   33 good
> comparisons. ok
> >    0:*** Testing test_ncmpi_strerror            ...   33 good
> comparisons. ok
> >    1:*** Testing test_ncmpi_strerror            ...   33 good
> comparisons. ok
> >    3:*** Testing test_ncmpi_strerror            ...   33 good
> comparisons. ok
> >    0:
> >    1:
> >    2:
> >    2: FAILURE at line 149 of test_read.c: remove of ./scratch.nc
> failed*** Testing test_ncmpi_open                ...
> >    2: ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
> >    0:*** TESTING C   ./nc_test for format CDF-1
>  ------ failed
> >    0:
> >    0: FAILURE at line 149 of test_read.c: remove of ./scratch.nc
> >    0: ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
> >    0:
> >    0:./nc_test: expects 0 failures ... Total number of failures: 1
> >    1:*** TESTING C   ./nc_test for format CDF-1
>  ------ failed
> >    1:
> >    1: FAILURE at line 149 of test_read.c: remove of ./scratch.nc
> >    1: ### 1 FAILURES TESTING test_ncmpi_open! Stop ... ###
> >    1:
> >    1:./nc_test: expects 0 failures ... Total number of failures: 1
> >    2:*** TESTING C   ./nc_test for format CDF-1
>  ------ failed
> >    2:
> >    2:
> >    2:./nc_test: expects 0 failures ... Total number of failures: 1
> >    3:*** Testing test_ncmpi_open                ...    5 good
> comparisons. ok
> > and the parallel test fail in the build step with:
> > glade/apps/opt/modulefiles/ys/cmpwrappers/mpif90 -c -g  -O0
> -I../../src/lib  -I../../src/libf -I../../src/libf90  mcoll_testf.f90
> > mcoll_testf.f90:257:22:
> >          t1 = MPI_Wtime ( )
> >                       1
> > Error: Name 'mpi_wtime' at (1) is an ambiguous reference to 'mpi_wtime'
> from module 'mpi_constants'
> > mcoll_testf.f90:292:22:
> >          t2 = MPI_Wtime ( )
> >                       1
> > mcoll_testf.f90:313:20:
> >        t3 = MPI_Wtime ( )
> >                     1
> > All with svn revision 2056​
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150720/0ec46057/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150720/0ec46057/attachment-0001.bin>
