pnetcdf test/DRY RUN Error in wrf simulation
Wei-keng Liao wkliao at eecs.northwestern.edu
Sat Jun 7 13:07:23 CDT 2014
Hi, Basit
I just ran a WRF V3.6 test case and did not see the same error message.
It seems that you are using WRF V3.5.1. I guess V3.6 must fix the error.
Could you try V3.6?
Wei-keng
On Jun 5, 2014, at 4:00 AM, BasitAli Khan wrote:
> Hi Wei-Keng and Rob,
> Thanks for the prompt responses. Thanks for spotting snippet from the
> wrong file. I get the above mentioned warnings only when i activate
> pnetcdf that is io_form_* = 11. If i don't use pnetcdf i.e. io_form_*=2
> the wrf sim runs perfect without any warning and/or error.
> Sorry, not sure about "WRF_FILE_OPENED_NOT_COMMITTED" as i am not quite
> familiar with pnetcdf stuff.
> A detailed description of the supercomputing lab(shaheen) is also
> available at https://www.hpc.kaust.edu.sa/documentation/user_guide/
> Following is the system info + how i compiled wrf, netCDF and pnetCDF
> - uname --all
> Linux fen1 2.6.16.60-0.97.1-ppc64 #1 SMP Tue May 29 19:21:39 UTC 2012
> ppc64 ppc64 ppc64 GNU/Linux
> basitali at fen1:~$ lsb_release -a
> LSB
> Version:        core-2.0-noarch:core-3.0-noarch:core-2.0-ppc:core-3.0-ppc:desktop-
> 3.1-noarch:desktop-3.1-ppc32:graphics-2.0-noarch:graphics-2.0-ppc32:graphic
> s-3.1-noarch:graphics-3.1-ppc32
> Distributor ID: SUSE LINUX
> Description:    SUSE Linux Enterprise Server 10 (ppc)
> Release:        10
> Codename:       n/a
> - The configure.wrf files is attached that describes the wrf compile setup
> - The configure statement for pnetCDF is as follows:
> ./configure --host powerpc64-bgp-linux --build ppc64-suse-linux
> --prefix=/home/basitali/parallel_netCDF
> --with-mpi=/bgsys/drivers/ppcfloor/comm/xl MPICC=mpixlc MPICXX=mpixlcxx
> MPIF77=mpixlf77 MPIF90=mpixlf90 FFLAGS="-qsuppress=cmpmsg"
> FCFLAGS="-qsuppress=cmpmsg"
> - The configure statement for netCDF 4.1.2 is as follows:
> ./configure --prefix=/home/basitali/netCDF_4.1.2 CC="mpixlc -qarch=450d
> -qtune=450" CXX="mpixlcxx_r -O3 -qarch=450d -qtune=450" FC="mpixlf90_r -O3
> -qarch=450d -qtune=450" F77="mpixlf90_r -O3 -qarch=450d -qtune=450"
> CFLAGS="-I/home/basitali/netCDF_4.1.2/include -DIBMR2Fortran
> -I/opt/share/zlib/1.2.5/bgp-ibm/include"
> LIBS="-L/home/basitali/netCDF_4.1.2/lib
> -L/opt/share/zlib/1.2.5/bgp-ibm/lib -lnetcdf  -lz -lm" FFLAGS="-g
> -I/home/basitali/netCDF_4.1.2/include"
> FCFLAGS="-I/home/basitali/netCDF_4.1.2/include -DIBMR2Fortran
> FLIBS="-L/home/basitali/netCDF_4.1.2/lib -lnetcdff
> -L/opt/share/zlib/1.2.5/bgp-ibm/lib -lnetcdf -lz -lm" CXXFLAGS="-qpic
> -DIBMR2Fortran -I/home/basitali/netCDF_4.1.2/include
> -I/opt/share/zlib/1.2.5/bgp-ibm/include" CPPFLAGS="-qpic -DIBMR2Fortran
> --with-zlib=/opt/share/zlib/1.2.5/bgp-ibm --disable-netcdf-4
> --enable-pnetcdf --with-pnetcdf=/home/basitali/parallel_netCDF
> --disable-dap --disable-shared
> uname
> - The result of nc-config --all is as follows
> --cc        -> mpixlc -qarch=450d -qtune=450
>  --cflags    ->  -I/home/basitali/netCDF_4.1.2/include
>  --libs      -> -L/home/basitali/netCDF_4.1.2/lib -lnetcdf
>  --cxx       -> mpixlcxx_r -O3 -qarch=450d -qtune=450
>  --has-c++   -> yes
>  --fc        -> mpixlf90_r -O3 -qarch=450d -qtune=450
>  --fflags    -> -g -I/home/basitali/netCDF_4.1.2/include
>  --flibs     -> -L/home/basitali/netCDF_4.1.2/lib -lnetcdff -lnetcdf
>  --has-f77   -> yes
>  --has-f90   -> yes
>  --has-dap   -> no
>  --has-nc2   -> yes
>  --has-nc4   -> no
>  --has-hdf5  -> no
>  --has-hdf4  -> no
>  --has-pnetcdf-> yes
>  --has-szlib -> no
>  --prefix    -> /home/basitali/netCDF_4.1.2
>  --includedir-> /home/basitali/netCDF_4.1.2/include
>  --version   -> netCDF 4.1.2
> Please have a look. I would greatly appreciate your help and advise in
> this regard.
> Best regards,
> b:)
> Basit A. Khan, Ph.D.
> Postdoctoral Research Fellow
> Division of Physical Sciences & Engineering
> Office# 3204, Level 3, Building 1,
> King Abdullah University of Science & Technology
> 4700 King Abdullah Blvd, Box 2753, Thuwal 23955 ­6900,
> Kingdom of Saudi Arabia.
> Office: +966(0)12 808 0276,  Mobile: +966(0)5 0860 3617
> E-mail: basitali.khan at kaust.edu.sa
> Skype name: basit.a.khan
> On 6/4/14 6:54 PM, "Wei-keng Liao" <wkliao at eecs.northwestern.edu> wrote:
>> Hi, Basit
>> The file wrf_io.F90 should be the one in external/io_pnetcdf.
>> So the code fragment is like
>> 2399   elseif(DH%FileStatus == WRF_FILE_OPENED_NOT_COMMITTED) then
>> 2400     do NVar=1,MaxVars
>> 2401       if(DH%VarNames(NVar) == VarName ) then
>> 2402         Status = WRF_WARN_2DRYRUNS_1VARIABLE
>> 2403         write(msg,*) 'Warning 2 DRYRUNS 1 VARIABLE
>> (',TRIM(VarName),') in ',__FILE__,', line', __LINE__
>> 2404         call wrf_debug ( WARN , TRIM(msg))
>> 2405         return
>> 2406       elseif(DH%VarNames(NVar) == NO_NAME) then
>> It looks to me is the file is yet to be closed.
>> Could you let us know how you build WRF (commands) and the test case (and
>> parameters)
>> that you run? I may give it a try to see if I can repeat your experiment
>> and observe the same errors.
>> Wei-keng
>> On Jun 4, 2014, at 10:09 AM, BasitAli Khan wrote:
>>> Hi Rob,
>>> Following is the snippet of the subroutine in wrf_io.F90. Actually line
>>> 2403 is just a variable declaration.
>>> 2380 subroutine
>>> ext_ncd_write_field(DataHandle,DateStr,Var,Field,FieldTypeIn,  &
>>> 2381   Comm, IOComm, DomainDesc, MemoryOrdIn, Stagger,  DimNames,
>>> 2382
>>> DomainStart,DomainEnd,MemoryStart,MemoryEnd,PatchStart,PatchEnd,Status)
>>> 2383   use wrf_data
>>> 2384   use ext_ncd_support_routines
>>> 2385   implicit none
>>> 2386   include 'wrf_status_codes.h'
>>> 2387   include 'netcdf.inc'
>>> 2388   integer                       ,intent(in)    :: DataHandle
>>> 2389   character*(*)                 ,intent(in)    :: DateStr
>>> 2390   character*(*)                 ,intent(in)    :: Var
>>> 2391   integer                       ,intent(inout) :: Field(*)
>>> 2392   integer                       ,intent(in)    :: FieldTypeIn
>>> 2393   integer                       ,intent(inout) :: Comm
>>> 2394   integer                       ,intent(inout) :: IOComm
>>> 2395   integer                       ,intent(in)    :: DomainDesc
>>> 2396   character*(*)                 ,intent(in)    :: MemoryOrdIn
>>> 2397   character*(*)                 ,intent(in)    :: Stagger ! Dummy
>>> for
>>> now
>>> 2398   character*(*) ,dimension(*)   ,intent(in)    :: DimNames
>>> 2399   integer       ,dimension(*)   ,intent(in)    :: DomainStart,
>>> DomainEnd
>>> 2400   integer       ,dimension(*)   ,intent(in)    :: MemoryStart,
>>> MemoryEnd
>>> 2401   integer       ,dimension(*)   ,intent(in)    :: PatchStart,
>>> PatchEnd
>>> 2402   integer                       ,intent(out)   :: Status
>>> 2403   integer                                      :: FieldType
>>> 2404   character (3)                                :: MemoryOrder
>>> 2405   type(wrf_data_handle)         ,pointer       :: DH
>>> 2406   integer                                      :: NCID
>>> 2407   integer                                      :: NDim
>>> 2408   character (VarNameLen)                       :: VarName
>>> 2409   character (3)                                :: MemO
>>> 2410   character (3)                                :: UCMemO
>>> 2411   integer                                      :: VarID
>>> 2412   integer      ,dimension(NVarDims)            :: Length
>>> 2413   integer      ,dimension(NVarDims)            :: VDimIDs
>>> 2414   character(80),dimension(NVarDims)            :: RODimNames
>>> 2415   integer      ,dimension(NVarDims)            :: StoredStart
>>> 2416   integer      ,dimension(:,:,:,:),allocatable :: XField
>>> 2417   integer                                      :: stat
>>> 2418   integer                                      :: NVar
>>> 2419   integer                                      :: i,j
>>> 2420   integer                                      :: i1,i2,j1,j2,k1,k2
>>> 2421   integer                                      :: x1,x2,y1,y2,z1,z2
>>> 2422   integer                                      :: l1,l2,m1,m2,n1,n2
>>> 2423   integer                                      :: XType
>>> 2424   integer                                      :: di
>>> 2425   character (80)                               :: NullName
>>> 2426   logical                                      :: NotFound
>>> 2427
>>> Cheers,
>>> b:)
>>> On 6/4/14 4:58 PM, "Rob Latham" <robl at mcs.anl.gov> wrote:
>>>> On 06/04/2014 01:55 AM, BasitAli Khan wrote:
>>>>> Hi there,
>>>>> I sent you the following email a a weak ago regarding pnetcdf  make
>>>>> check  errors, but did not get response. I used this pnetcdf to
>>>>> compile
>>>>> netCDF library 4.1.2. The pnetcdf was successfully linked and netCDF
>>>>> was
>>>>> successfully compiled. I ran a WRF simulation which also was completed
>>>>> successfully, however, the log file rsl.out.0000 (attached ) has
>>>>> several
>>>>> (DRY RUN) errors that are originating from pnetCDF. I am wondering
>>>>> what
>>>>> these errors are and would they be affecting my simulation in anyway?
>>>>> Thanks in advance and please do REPLY this email.
>>>> Hello! sorry for the oversight.  Here is my (list-only) reply from last
>>>> week:
>>>> http://lists.mcs.anl.gov/pipermail/parallel-netcdf/2014-May/001574.html
>>>> Thanks for subscribing to the mailing list.
>>>> There are folks using pnetcdf and WRF on Blue Gene.  I don't know the
>>>> details, but it apparently is possible.  I think we can get you
>>>> straightened out.
>>>> When you see errors like this:
>>>> /bin/sh: line 1:  6418 Illegal instruction     ./nc_test -c -d .
>>>> it means you are running back-end code on the login nodes.  Blue Gene
>>>> is
>>>> a cross-compile environment: compute node codes cannot run on the login
>>>> nodes.  (well, technically they can... until they make a system call)
>>>> what does line 2403 of wrf_io.f90 look like?
>>>> ==rob
>>>> Hi Rob,
>>>>> Best regards,
>>>>> b:)
>>>>> E-mail: basitali.khan at kaust.edu.sa <mailto:basitali.khan at kaust.edu.sa>
>>>>> From: KAUST <basitali.khan at kaust.edu.sa
>>>>> <mailto:basitali.khan at kaust.edu.sa>>
>>>>> Date: Wednesday, May 28, 2014 3:05 PM
>>>>> To: "parallel-netcdf at mcs.anl.gov <mailto:parallel-netcdf at mcs.anl.gov>"
>>>>> <parallel-netcdf at mcs.anl.gov <mailto:parallel-netcdf at mcs.anl.gov>>
>>>>> Subject: pnetcdf test
>>>>> Hi there,
>>>>> I am new to pnetcdf. I want to compile it for faster IO  of WRF model
>>>>> on
>>>>> our bluegeneP with Linux RedHat 10 on it. I apparently successfully
>>>>> installed the latest version of pnetcdf 1.4.1, however when i run
>>>>> 'make
>>>>> testing', i got few errors (log file attached).  I would greatly
>>>>> appreciate if you could have a look and advise where i am going wrong.
>>>>> The compilation of parallel netcdf created 4 directories. The contents
>>>>> of these dir are as follows:
>>>>> /lib/libpnetcdf.a
>>>>> /include/pnetcdf.h  pnetcdf.inc  pnetcdf.mod
>>>>> /bin/ncmpidiff  ncmpidump  ncmpigen  ncmpivalid
>>>>> /man/man1/ncmpidiff.1  ncmpidump.1  ncmpigen.1  ncmpivalid.1
>>>>> /man/man3/pnetcdf.3  pnetcdf_f77.3  pnetcdf_f90.3
>>>>> Another question is that, do i have to do anything special to use it
>>>>> with WRF?
>>>>> Thanks in advance and best regards,
>>>>> b:)
>>>>> This message and its contents including attachments are intended
>>>>> solely
>>>>> for the original recipient. If you are not the intended recipient or
>>>>> have received this message in error, please notify me immediately and
>>>>> delete this message from your computer system. Any unauthorized use or
>>>>> distribution is prohibited. Please consider the environment before
>>>>> printing this email.
>>>> Rob Latham
>>>> Mathematics and Computer Science Division
>>>> Argonne National Lab, IL USA
>>> ________________________________
>>> This message and its contents including attachments are intended solely
> This message and its contents including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
> <configure.wrf>
