Building errors relating to undefined reference of 'nfmpi_*'
Li Dong dongli at lasg.iap.ac.cn
Thu May 30 20:08:24 CDT 2013
Dear Wei-keng,
Thank you for helping! Here is the output in the attachment.
Li
Dr. Li Dong (董理)
LASG, Institute of Atmospheric Physics
Chinese Academy of Sciences
P.O. Box 9804
Beijing 100029, China
Phone: 8610-8299 5143
在 2013-5-30,下午10:43,Wei-keng Liao <wkliao at ece.northwestern.edu> 写道:
> Hi, Li
> It looks like the fortran part of PnetCDF failed to build.
> Could you send us the standard output from the screen when you run "make" command?
> You can do the following command and send us the file "make.output".
> make -s clean; make >& make.output
> Wei-keng
> On May 30, 2013, at 2:48 AM, Li Dong wrote:
>> Dear PnetCDF supporters,
>> When I build parallel-netcdf on our server, I invoked 'make tests' after 'make' and encountered the following errors:
>> /apps/intel/impi/4.0.2.003/intel64/bin/mpiifort -o bigrecords bigrecords.o -L../../src/lib  -lpnetcdf
>> bigrecords.o: In function `MAIN__':
>> bigrecords.F:(.text+0xb0): undefined reference to `nfmpi_create_'
>> bigrecords.F:(.text+0xe6): undefined reference to `nfmpi_def_dim_'
>> bigrecords.F:(.text+0x12b): undefined reference to `nfmpi_def_dim_'
>> bigrecords.F:(.text+0x170): undefined reference to `nfmpi_def_dim_'
>> bigrecords.F:(.text+0x1c2): undefined reference to `nfmpi_def_var_'
>> bigrecords.F:(.text+0x214): undefined reference to `nfmpi_def_var_'
>> bigrecords.F:(.text+0x282): undefined reference to `nfmpi_def_var_'
>> bigrecords.F:(.text+0x2d3): undefined reference to `nfmpi_put_att_text_'
>> bigrecords.F:(.text+0x324): undefined reference to `nfmpi_put_att_text_'
>> bigrecords.F:(.text+0x375): undefined reference to `nfmpi_put_att_text_'
>> bigrecords.F:(.text+0x3c6): undefined reference to `nfmpi_put_att_text_'
>> bigrecords.F:(.text+0x417): undefined reference to `nfmpi_put_att_text_'
>> bigrecords.o:bigrecords.F:(.text+0x468): more undefined references to `nfmpi_put_att_text_' follow
>> bigrecords.F:(.text+0x486): undefined reference to `nfmpi_enddef_'
>> bigrecords.F:(.text+0x4d2): undefined reference to `nfmpi_put_vara_real_all_'
>> bigrecords.F:(.text+0x557): undefined reference to `nfmpi_put_vara_double_all_'
>> bigrecords.F:(.text+0x57e): undefined reference to `nfmpi_close_'
>> bigrecords.F:(.text+0x5c2): undefined reference to `nfmpi_open_'
>> bigrecords.F:(.text+0x5f2): undefined reference to `nfmpi_inq_varid_'
>> bigrecords.F:(.text+0x63e): undefined reference to `nfmpi_get_vara_double_all_'
>> bigrecords.F:(.text+0x65c): undefined reference to `nfmpi_close_'
>> bigrecords.o: In function `writerecs_':
>> bigrecords.F:(.text+0x1165): undefined reference to `nfmpi_put_vara_double_all_'
>> ../../src/lib/libpnetcdf.a(strerrorf.o): In function `nfmpi_strerror_':
>> strerrorf.f:(.text+0x15): undefined reference to `nfmpi_xstrerror_'
>> make[2]: *** [bigrecords] Error 1
>> The config.log file is in the attach and the results of 'uname -a' are:
>> Linux ln1 2.6.18-194.17.1.0.1.el5_lustre.1.8.5 #1 SMP Wed Aug 3 18:09:09 CST 2011 x86_64 x86_64 x86_64 GNU/Linux
>> How to solve this problem? Thanks in advance!
>> Best regards,
>> Li
>> <config.log>
>> Dr. Li Dong (董理)
>> P.O. Box 9804
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130531/486bb4c0/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130531/486bb4c0/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130531/486bb4c0/attachment-0003.html>
