Crash if trying to write a parameter or a constant in a Fortran application
Rob Latham robl at mcs.anl.gov
Tue Jul 9 15:40:18 CDT 2013
On Tue, Jul 09, 2013 at 11:17:15AM -0500, Wei-keng Liao wrote:
> NetCDF 3 and 4 pass the test, because they do internal caching. So
> byte-swap is done on the cache buffer and the memory contents of
> Fortran parameters are not touched.
Ah, right, thank you for reminding me about the netcdf internal cache.
I'm tempted to just document this in the release notes, unless there's
a reasonably small threshold: for example, "if number of items is less
than 1024, make a copy for byteswapping in case it's a parameter"
==rob
> Wei-keng
> On Jul 9, 2013, at 10:14 AM, Rob Latham wrote:
> > On Tue, Jul 09, 2013 at 08:53:24AM -0500, Rob Latham wrote:
> >> Does serial netcdf exhibit this behavior?
> > Here's my serial netcdf-f90 version of your test case, but it's buggy:
> > I am apparently trying to write to a variable that does not exist?
> > Our policy is to be as netcdf-like as possible, or have a good reason
> > not to be, and I'd like to know how serial netcdf handles the case of
> > byte swapping data passed to it in this un-modifiable parameter form.
> > ==rob
> > Rob Latham
> > Mathematics and Computer Science Division
> > Argonne National Lab, IL USA
> > <netcdf_parameter.f90>
Rob Latham
