Write a 3D array in Fortran using PnetCDF
MBR MBR mbr.joos at gmail.com
Mon Jan 28 04:40:10 CST 2013
Hi Rob,
Please find enclosed a fully working test case to write a variable
collectively, using ParallelNetCDF.
I took the liberty to add few things I was trying to do and for which I
also struggled a little bit; the program remains however very simple. The
program is first creating a small variable (kind of metadata), which is
created and written by solely one thread, and then the file is re-open and
the variable is written collectively by all the MPI threads.
Best,
MBR
On Fri, Jan 25, 2013 at 7:37 PM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Fri, Jan 25, 2013 at 07:08:00PM +0100, MBR MBR wrote:
> > Hi Wei-keng,
> > The problem was indeed the start... xpos, ypos & zpos started at 0, and I
> > re-used what I did in parallel HDF5, where the "start" index start at 0
> as
> > in C.
> > Thanks, and sorry for the dumb question!
> Hi MBR: Glad Wei-keng could fix you up so quickly. Can you contribute
> a driver for this routine?  We are always looking for small-ish test
> cases we can add to our test suite, even tests that are supposed to
> fail.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130128/401957af/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130128/401957af/attachment.obj>
