Write a 3D array in Fortran using PnetCDF
Rob Latham robl at mcs.anl.gov
Fri Jan 25 12:37:15 CST 2013
On Fri, Jan 25, 2013 at 07:08:00PM +0100, MBR MBR wrote:
> Hi Wei-keng,
> The problem was indeed the start... xpos, ypos & zpos started at 0, and I
> re-used what I did in parallel HDF5, where the "start" index start at 0 as
> in C.
> Thanks, and sorry for the dumb question!
Hi MBR: Glad Wei-keng could fix you up so quickly. Can you contribute
a driver for this routine?  We are always looking for small-ish test
cases we can add to our test suite, even tests that are supposed to
fail.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
