how the collective io take effects?
Liu, Jaln jaln.liu at ttu.edu
Mon Nov 26 01:02:58 CST 2012
Hi all,
please see the following codes first,
  mpi_start[] = ..;
  mpi_count[] = ..;
  ncmpi_get_vara_float_all();
I can see the collective i/o is performed in the *_all function, which means all processes will call this function to do the i/o.
What if I write the code in the following way,
    loop_start=(int)(NREC/nprocs)*rank;
    loop_length=(int)(NREC/nprocs);
    /*parallel access datasets*/
    for(rec = loop_start;rec <loop_start+loop_length; rec++)
      for(lon = 0; lon < NLON; lon++){
      mpi_start[0] = rec;
      mpi_start[2] = lon;
      ret = ncmpi_get_vara_float_all()
In the above codes, the outer loop is decomposed, then how the collective i/o will take effect in this case, if I specify mpirun -np 10 here.
In other word, can all the 10 processes cooperate with each other to do collective I/O anymore in this example?
If there is something wrong in my understanding, please point it out, thanks in advance.
Jialin
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20121126/79788bec/attachment.html>
