error in nonblocking.c?
Wei-keng Liao wkliao at ece.northwestern.edu
Thu Nov 15 13:42:54 CST 2012
Hi, Jim,
NC_REQ_NULL is to be used by the pnetcdf nonblocking APIs.
It is not intended to be the same as MPI_REQUEST_NULL.
Could you explain why your case will desire them to be the same?
Wei-keng
On Nov 15, 2012, at 1:37 PM, Jim Edwards wrote:
> So this program illustrates the problem:
> #include <mpi.h>
> #include <stdio.h>
> #include <pnetcdf.h>
> int main()
>   printf("%d %d\n",MPI_REQUEST_NULL,NC_REQ_NULL);
> On Cray systems using pgi compiler:
> ./a.out
> 738197504 -1
> I can try using NC_REQ_NULL instead of MPI_REQUEST_NULL in my program, but I'm afraid that's just going to cause this problem to manifest in a different way.
> On Thu, Nov 15, 2012 at 11:34 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> On Cray systems the MPI constant MPI_REQUEST_NULL resolves to 738197504
> but passing this value into nonblocking.c results in an error:
> Error: no such request ID = 738197504
> I think that this is an error in parallel-netcdf ncmpii_wait.
> On the ibm aix system MPI_REQUEST_NULL resolves to -1 and nonblocking.c seems to handle it correctly.
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
> Jim Edwards
> Boulder, CO
> 303-497-1842
